C63/C63S AMG
C63 Downpipe V Band Clamps leak, help needed
Old Jul 11, 2024 | 03:56 AM
Joey911's Avatar
W205 C63 Sedan
Unhappy C63 Downpipe V Band Clamps leak, help needed
Hey guys,
I've been battling with the V-band clamp leak issue for months now. Initially, we thought a bad downpipe caused the V-band to loosen (not the bolt loosening, but the V of the V-band spreading loose). However, after purchasing a reputable brand downpipe with 100 cell front and 100 cell rear, it still deformed the V-band. The next step is to install brand new V-band clamps.
Here's what I tried (with reused V-bands):
  • Buffed the V surface smooth
  • Cleaned the outer flange surface, free of debris
  • Applied copper anti-seize on the V so it could slide on evenly all the way around
  • Torqued it to 5 Nm wet (not sure of the factory spec, probably even lower in inch-pounds). Once it clicked, I used a rubber hammer on the opposite side and torqued it to 5 Nm again. Repeated until I couldn't tighten any further after tapping with the hammer.
I was able to seal it with no leak when idling or driving around town, but when driving with boost up (JB4 map 1), it would blow open, and I could hear the "blah blah blah" exhaust tone near reflecting surfaces.
I was wondering if anyone could pull up an installation guide on how to reinstall the catalytic converter on M177 engines, especially the part of V-band installation.
Thanks, Joey
Old Jul 15, 2024 | 02:18 AM
Joey911's Avatar
W205 C63 Sedan
