C63/C63S AMG
C63S ACTIVE ENGINE MOUNT REPLACEMENT / OPTIONS
Old Aug 24, 2024 | 06:09 AM
k4inZa's Avatar
w205 C63s edition 1
I need to replace my Engine Mounts on my W205 2015 C63s they are active (well atleast they used to be).
The unit has failed and throws an error.
Mercedes don’t have stock in SA
I can’t find any second hand either.
I was wondering if it’s possible to use the standard mount (non active) and updating the software to remove the error / switch off the active mounts.
I have not been able to find much info online - I am . South Africa
Old Sep 10, 2024 | 04:54 PM
Bigbash's Avatar
E55 AMG, C63s T, SLK55, S55, ML63, E30 M3, E36 M3, E34 540 6sp
Should be simple coding out that option. If there are any tuners in your area maybe they can check in their software?
Old Sep 16, 2025 | 04:05 AM
k4inZa's Avatar
w205 C63s edition 1
Found a set - swapped it out - good as new
Old Sep 18, 2025 | 02:38 PM
AMGRectron's Avatar
2015 C63s Edition 1
How much was it?
