C63/C63S AMG
Sensor Errors? Aux Battery? Software update?
Old Aug 28, 2024 | 01:55 PM
bartek's Avatar
2016 C63s
Exclamation Sensor Errors? Aux Battery? Software update?
Hi All
My 2016 C63s started showing these - hope to get some direction from your experiences before making a trip to the dealer (would like to avoid it if this is a DIY).
Appreciate your insights/guidance, thank you!
panel messages
scan results
Old Aug 28, 2024 | 04:23 PM
W205C43PFL's Avatar
Originally Posted by bartek
Hi All
panel messages
scan results
Could be a voltage issue, like a bad 12V battery and/or aux battery.
Old Aug 28, 2024 | 05:41 PM
bartek's Avatar
2016 C63s
A great point, I have ordered the aux battery as it was the original, thanks for that!
Old Aug 28, 2024 | 05:45 PM
W205C43PFL's Avatar
You're welcome, hopefully that does the trick! There is also a possibility of a loose cable, check all the cables under the front passenger seat, certainly possible to accidentally knock one off.
Old Aug 31, 2024 | 12:42 PM
trigital's Avatar
W213 All-terrain
I would suspect the Distronic Radar with a little bump, cracks, water ingress
Old Sep 3, 2024 | 05:26 PM
bartek's Avatar
2016 C63s
>> Distronic Radar
If we're talking water, we're probably talking a replacement... Is this a DIY and is the unit expensive? (I'm not a mechanic...)
Old Sep 3, 2024 | 05:30 PM
trigital's Avatar
W213 All-terrain
If is about the Long range radar then is very expensive.
But first a proper diagnosis is mandatory
