C63/C63S AMG
Tyre size
Old Jan 7, 2025 | 01:41 PM
Dee205sedan's Avatar
Tyre size
Hey guys I just got my c63s sedan tuned to 650 whp having a bit of trouble hooking up when I launch I was thinking of get some slicks for when I’m going for drags. Was considering weld wheels but I’m lost when comes to the size I should get if anyone can help I’d really appreciate it.
Old Jan 16, 2025 | 11:07 PM
LessIsMore's Avatar
2017 AMG C63
You might consider fitting a taller wheel for increased straight line traction (wider tires change but usually don't increase your contact patch). But if you can get away with a tall tire (i.e. if stock is 26.2", try a 27") without runnig into ABS/speed sensor issues, it will increase your straightline contact patch to a greater degree than a wider tire, and slightly lower your effectively gear ratio as well, which is good for traction.
The widest tire I've seen someone fit on the back on a streetable sedan is 295 if you don't want headaches. Now, many have done 305's in back but it gets iffy on clearance, fenders cutting, etc. Your tire size depends on your wheels offset as well.
Old Jan 19, 2025 | 12:37 PM
FromV4_to_C63's Avatar
2021 AMG C63 Coupe
You wan to race a 4 door C63s. <<< bruh
Anyhow go buy some 395s Rear MIch PS4s and enjoy the track day.
Slicks wont matter your not beating anyone.... just enjoy the Track time
