C63/C63S AMG
Facelift 9 Stage Traction Control
Old Jul 14, 2025 | 09:30 AM
deanoo's Avatar
2019 C63S
I currently have a facelift C63s Coupe that has the 9 stage traction control system, car is making 740whp and i struggle to put the power down if even i have the traction setting on 5 for example
Current tyres are Michelin Cup 2's and they have seen better days so i know that plays a role with the traction issue (will be changing tyres just trying to decide what to go with)
My previous tyre choice was the Toyo R888R they worked better then the Cup 2's but they are just too damn loud and i still had traction issues depending on what traction setting i selected
I know people use the NT555Rii but there is no one locally that brings them in, same with mickey thompson's i cant get my hands on them
My question is, is there anyone else with the same or similar power experiencing the same issue? or if they had this issue what traction setting and tyre combo did you go with to better your traction?
Old Jul 14, 2025 | 11:57 AM
superswiss's Avatar
2019 C63CS
Everybody who tunes these cars finds themselves struggling to actually put the power down. These cars even have difficulty hooking up with stock power if you don't properly shift the weight to the rear and get your rear tires up to temp first. Just a couple of thoughts I've shared before.
  1. Tuners generally don't reprogram ESP and TC to properly work with the additional torque and power. Especially the 9-Stage TC is tightly integrated with the ECU's torque management. As opposed to traditional TC systems, it doesn't rely on the brakes to get traction, instead it manages the engine torque output. So if your engine runs out of stock spec, don't expect it to do its job well unless the tuner completely revised it to work with the tuned power and torque.
  2. Tires need to be hot. The chart below is from a Michelin presentation and shows you where your compound temps need to be for your Cup 2s to even develop their full grip potential. You gonna have to do a few burnouts to get anywhere near to the 200F compound temps required for 100% grip. Don't expect other high performance tires to perform better when cold. If you want more grip at lower compound temperatures, then you need to use an AS tire, but those start to fall off once they get hot as you can see from the graph. They peak just when the summer performance tires get started. Pull up your tire temp gauge in the instrument cluster and make sure your rear tires are properly hot before expecting them to even remotely hook up and roll your foot on the throttle to smoothly, but quickly shift the weight of the car to the rear and keep it there. These cars have more weight on the front, so you need to take advantage of the weight shift during acceleration if you want a chance to hook up. Even with my stock power, I can't get the power down if my rear tires aren't up to temperature.
Old Jul 14, 2025 | 03:22 PM
jj18's Avatar
2019 C63S Coupe
Believe the Yellow warning (passenger front) comes on at or close to155F. I know the Red warning comes on at 170F. (passenger front). When these tires get hot they get glued to the road and fun to drive. I have the Michelin Pilot Sport 4S. A new set this year. Cannot see if it's even possible to get the rears anywhere 200F based on my photo below?
Old Jul 14, 2025 | 03:49 PM
superswiss's Avatar
2019 C63CS
Yep, it's nearly impossible to get the rears hot enough w/o doing burnouts. 127-130F is about what I manage mine on a canyon run, with the fronts, at least the right going into the 170s. I agree, it's amazing how the PS4S starts to stick even at those temperatures. They are basically at 90-100% grip at that point. The brakes also become much better once the tires got heat in them as the fronts just dig in.
