C63/C63S AMG
Any idea what this noise this?
Old Jul 28, 2025 | 01:06 AM
jaydp's Avatar
'19 C63 Cabriolet
Hi all. 2019 c63 cab here. Car was recently serviced and passed with flying colors. Runs great.
However, I have this very faint metallic ringing or squeaking noise that can be heard when I mount a mic on the bumper near the exhaust. In the car with the top up or down, you cannot hear the noise. Can only be heard in these mic recordings.
Conditions:
- can be heard on all drive modes
- louder and more sustained in sport+. In comfort it goes away much faster.
- only seems to happen at 3k rpm or higher and 50mph or faster
- blipping the throttle will make the noise flare up
- sound dies when off throttle and once the speed and/or rpm drops below what’s mentioned above
Video of sound here.
sound happens when I let off throttle and the car is cruising. I blip the throttle again mid cruise and the sound flares up, and slowly goes down again
What do you guys think? Any ideas?
Old Jul 28, 2025 | 02:04 AM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
I think you discovered why mb does not recommend an external mic. Are you concerned by the 'crashing' sound? Is this normal gear change ruckus only privy to a bumper cam? I don't hear a ringing noise. Someone more knowledgeable will chime in.
Old Jul 28, 2025 | 02:56 AM
PeterUbers's Avatar
Why did you put a mic on the bumper if you can't hear it in regular driving?
Old Jul 28, 2025 | 03:40 AM
superswiss's Avatar
2019 C63CS
I've listened to the video a few times and I'm not sure what I'm supposed to hear. All I hear is exhaust pretty much. Having said that, I've never mounted a mic on the rear bumper, but there are moving parts back there. Your suspension is bouncing up and down, the valves inside of the dampers are continuously adjusting the damping, the rear differential actuator is adjusting the locking ratio of the diff constantly and the exhaust valves fully open above about 3k and partially close below. There's stuff going on in these cars and those things sometimes make noise. I agree with @PeterUbers , if you can't hear it w/o a mic near the source what are you trying to chase down? A likely normal noise that doesn't make it into the cabin?
Old Jul 28, 2025 | 09:46 AM
Roysup's Avatar
2018 C63S AMG Coupe, 2019 Jaguar F-Pace SVR
Can't hear anything the OP is describing.
Old Jul 28, 2025 | 09:47 AM
jaydp's Avatar
'19 C63 Cabriolet
To those asking why I put a mic if I can’t hear it in cabin or why I put a mic at all, it’s there because I intend on making car content. Good car sound does not come recording audio in cabin, it comes from mic’ing the car. All your favorite professional channels do this.
So for those wondering, the mic was not placed to diagnose the problem, but rather it found the problem.
Ive watched plenty of mic’d up cars, including c63, that DO NOT make this metallic sound.
The sound is definitely there as the issue was brought up to me by friends who I shared some videos with. Also shared the video when I went to service and they said they can hear the sound but are not sure where it’s coming from because underneath the car looks fine.
Old Jul 28, 2025 | 09:50 AM
Sathinas's Avatar
S65
~bangs head on desk~
Old Jul 28, 2025 | 10:22 AM
PeterUbers's Avatar
My best guess is that it's the exhaust vibrating - some component therein
get under there and see if anything replicates the sound with some gentle tapping
Old Jul 28, 2025 | 10:28 AM
jaydp's Avatar
'19 C63 Cabriolet
how does this help brother other than adding to your super member post count?
Old Jul 28, 2025 | 10:32 AM
jaydp's Avatar
'19 C63 Cabriolet
Thought this too. Got under the car and touched everything and also sprayed silicone lubricant on the active exhaust parts as per YouTube videos of similar diagnostic.
sound still persists…
Old Jul 28, 2025 | 10:48 AM
Sathinas's Avatar
S65
Seems you're looking for a solution to a problem that doesn't exist. It's a freaking car, with lots of turning and moving parts! I'm surprised you didn't put a microphone in the wheel well(s) and ask about that noise the tires make when driving at 70MPH, because your friends heard it from their car when they were next to you. I mean, what about that noisy thing thing in front of the windshield that makes more noise when you step on the accelerator? Have you considered installing a microphone under the hood as well?
Want a nice, silent car? Get an EV.
As far as postwhoring, I've been away at... a camp of sorts for the past 8 years. Gotta catch up on my post count.
Old Jul 28, 2025 | 11:22 AM
jaydp's Avatar
'19 C63 Cabriolet
very immature and child-like response. I’m assuming you didn’t see my follow up post on why I mic’d up the car.
get out my thread brother, you’re useless.
Old Jul 28, 2025 | 11:54 AM
PeterUbers's Avatar
Something is resonating INside the exhaust then ... muffler ... just enough with the drop in rpm's to manifest - shy of a swap out of parts I'm not sure how this ends
oh and also check the tightness of all bolts from engine to mufflers ... down pipes etc. I've seen subtle mis torqued (loose) bolts causing this
heat shields? Are they properly pulled back from contact?
rotor/brake heat shields (if your car has them?) are they contacting or a bit too close?
is there anything loose in trunk? Spare wheel install hardware, wrenches etc? Inside the walls of the trunk are modules that are attached with bolts and I had a rattle from an xm radio box (baaaaack in the day) that gave this elusive noise until tightened down
Old Jul 28, 2025 | 12:06 PM
Sathinas's Avatar
S65
Yeah, I don't think so. Maybe I'll postwhore in this thread for a while.
I'm not your brother. You wouldn't be the snowflake you are if you were my brother.
Yup. Not particularly useful to people like you.
Old Jul 28, 2025 | 12:32 PM
jaydp's Avatar
'19 C63 Cabriolet
Thank you for the thoughtful response. at service I had the tech check everything that could be loose and he said it’s all good. Under the car and trunk. Although of course there is the chance he missed something.
I feel like it is a sound resonating throughout the exhaust at this point. Is it possible it’s engine related and the sound is making its way out back through the exhaust?
you can hear the sound right? Lol
Old Jul 28, 2025 | 02:25 PM
user33's Avatar
In the video, I can't hear what you're describing and I am familiar with a mic mounted outside off the rear (for track-day video making) ... but it sounds like your mic is somewhat overloaded.
However, what you describe is similar to what my GTR Pro had ... metallic-like ping/ring within certain RPM ranges under load/throttle. In mine it was one of the exhaust valves and the entire exhaust was replaced under warranty. When the valves are such a (relatively) high-failure item, it seems strange that the engineers have stuck with an "all 1-piece system" as opposed to a design that would enable the valve to be replaced.
If you search the forum, you'll find that some people have opted to do various fixes for exhaust-system valve issues, including cut 'n weld approaches.
Although a different sound, on my C63 S, I also had a noise that occurred under load/throttle within an RPM range. In that case, as someone suggested, it turned out to be the exhaust system contacting a section of the heat-shield metal that had become slightly re-positioned. Sounds like your service people have eliminated this one. When you solve yours, it'd be interesting to know the conclusion.
Old Jul 28, 2025 | 02:58 PM
superswiss's Avatar
2019 C63CS
I agree, the recording quality isn't very good. That mic is definitely overloaded. Even with headphones I can't hear what's being described and am rather distracted by the poor audio quality.
OP, you should request that they fit the chassis ears to isolate where the noise is coming from.
Old Jul 28, 2025 | 04:04 PM
PeterUbers's Avatar
What the Benz mechanic says and what he actually did are often two totally different things, but you know that.
I hear the metallic rasp (faintly) in your clip and can understand that it's much more prevalent IRL while driving - it would prolly drive me nuts.
i highly doubt it's in the engine or turbo - those noises are different
Google turbo failing noises (loose turbo connections) and listen on YouTube - see if it sounds similar - those can be more prevalent during gearshifts
Old Jul 28, 2025 | 04:23 PM
jaydp's Avatar
'19 C63 Cabriolet
damn. I wish you could hear it since it sounds like you might have experience. YouTube’s dynamic compression might be making it hard to hear. Try upping to max quality on the YouTube app, not browser. It starts are 0:11 when I let off throttle, and “jingles” for seconds before fading out, then I blip the throttle again for half a second at around 0:21 which sparks up the jingle again.
my service guy said it’s probably the active exhaust which is why I already attempted to fix it going under the car, inspecting it, and spraying moving areas with silicone lubricant.
now I’m hearing from you guys it’s likely exhaust. All signs are pointing at exhaust so I guess I need to look deeper.
Old Jul 28, 2025 | 04:27 PM
jaydp's Avatar
'19 C63 Cabriolet
it’s not bothering me enough yet to take it in for a diagnostic like this but yes, this is the route, thank you.
Old Jul 28, 2025 | 04:31 PM
jaydp's Avatar
'19 C63 Cabriolet
finally someone can hear it. my ears are so attuned to it that I can’t not hear it anymore :/
Thank you for the help. Good to know it probably is not rooted at the front of the car
Old Jul 29, 2025 | 09:26 AM
Roysup's Avatar
I still don't hear it. The sound in your video is over-modulated, or my awesome Dell laptop speakers just can handle the power. Maybe not your rear exhaust valves, BUT... There's a TON of threads about the rattling 3rd active exhaust valve that is in the center of the H-pipe section. Perhaps that is what you are hearing. Some people have reported success in reducing the noise by packing enough copper grease between the servo motor and the backing plate that the valve can't rattle around anymore. Some people just take off the servo, put a valve simulator in the plug, and tack-weld the valve in the open position.
Old Jul 29, 2025 | 01:05 PM
jaydp's Avatar
'19 C63 Cabriolet
AMG performance exhaust in this generation does not have a 3rd valve in the H pipe section. Are you sure this is facts or information relevant to this generation/spec? I cannot find anything official with this information on this generation including MBZ exhaust diagrams.
Old Jul 29, 2025 | 03:03 PM
Roysup's Avatar
Okay, are you serious right now. I'm pretty sure that it is "facts or information relevant to this generation/spec". What I'm not sure about is the tone of your response . I was just trying to help even though your over-modulated video doesn't play it clearly. Do I know the exact configuration of every iteration of the W205... No. But I do own one, and it has the "performance exhaust", and it has the "third valve", and I've read numerous threads on the metallic rattling sound being caused by that third valve.
Old Jul 29, 2025 | 03:19 PM
japamg's Avatar
Final Edition C63s / RS3 Sportback
Conditions:
https://youtube.com/shorts/5nGZ5q1Wv...V-tdkO-Q2amkiO
You are kidding right? 🤣🤣🤣
