C63s car vibrates/shudders under load
I’m looking to see if anyone has experience or can point me in the right direction.
I have a 18 c63s and recently been experiencing an issue where under load at 40ish MPH whether in 4,5, or 6th gear when I’m at half throttle the entire car begins to shake and shudder. Originally it would also have a metal rattle noise that sounded like it was coming from the exhaust but it’s no longer doing that.
I checked all 3 exhaust valves and they’re fine, I did a transmission service with new fluid but did not fix problem.
Checked engine and transmission mount.
im really lost and trying to avoid taking it to dealer,
could this possibly be the torque converter?
It’s worse when it’s in comfort mode
I’ve plugged in Maxi scanner multiple times through out the week with no codes. Next step is trying xentry
It showing no codes has been very frustrating trying to pinpoint the problem. Motor mounts are also fine, it runs completely fine normal driving. Just when in comfort 50% throttle at 2k rpms it’ll start to shudder
Not in manual mode and the car downshifts when I rapidly hit the throttle half way. When I’m experiencing the issue is when I’m easing in on it so the car doesn’t think to downshift necessarily.
On WOT in sport doesn’t have any problems but I notice top end power is sluggish and feel like turbos aren’t performing. Almost like NA power.
After doing some reading I’ve learned that older version coil packs would have symptoms exactly like what I’m experiencing. I’m going to look into purchasing updated packs and seeing if that resolves.
(Below is what is said about old coils)
thanks
- Misfire Under Load
- Smooth at idle and light throttle.
- Shaking/vibration in higher gears at low RPM when boost builds.
- Feels like “power cutting in and out.
- Loss of Top-End Power
- Engine feels flat past ~4–5k RPM.
- Boost gauge shows pressure, but car doesn’t accelerate as hard (because cylinders aren’t firing cleanly)
- Clunk/Shake Around 2–3k RPM
- Especially noticeable in 5th–7th gear, half throttle.
- Feels like drivetrain vibration but is actually misfiring
thanks
Has this car been properly maintained? What's the mileage? Spark plugs changed at every 50k or 5 years whichever comes first? Is it tuned? Fouled spark plugs is common on tuned cars for example.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
