C63/C63S AMG
Will 2019 C63S AMG Coupe 19” and 20” wheels fit a 2015 C63S sedan?
Old Nov 2, 2025 | 10:21 PM
Hawaii-50's Avatar
1993 Mustang GT, 2015 F-350 King Ranch, 2015 C63 AMG S
Hello, I’m new to the site.
Just like the title says…. I have a 2015 C63S sedan with 19x8.5/9.5 grey machined AMG wheels.
Are the widths on the 2019 wheels, 9 and 10.5? Will I be able to fit a 255 on the fronts and a 295 on the rears without rubbing on the fenders?
Thanks in advance!
Old Nov 3, 2025 | 07:09 AM
superswiss's Avatar
2019 C63CS
Somebody who has tried it should be able to give a more definite answer, but as far as I know, the coupe wheels don't fit on the sedan as-is. Width is only one aspect of wheel fitment. Offset is the other. The offset controls how far the center of the wheel barrel is moved inwards or outwards relative to the hub. The coupe uses different offsets as it has a wider track than the sedan. So even if the width would technically fit, if the offset is not correct, then the wheel will be pushed too far in or out.
You can correct offset in one direction by using spacers to move the wheel outward as necessary, but you can't move it inward. I'm not at a computer at the moment, but there are wheel offset calculators online that let you compare two wheels to each other and see how they fit.
