C63/C63S AMG
No throttle response cold engine
Old Mar 27, 2026 | 06:36 AM
MK6-R20's Avatar
437 HP
Hello, After a cold start on my ‘17 C63s, while the RPMs are still slightly elevated, I put the car in Drive and gently press the throttle to move forward. The RPMs increase, but the car barely moves, almost as if it’s revving without properly engaging.
This only happens when the engine is cold. Once the RPMs drop back to normal, the car drives as expected. The RPMs usually settle after about 45–60 seconds.
Is this normal?
Old Mar 27, 2026 | 06:51 AM
C63s_Jack's Avatar
AMG C63s Coupe
Originally Posted by MK6-R20
Is this normal?
Totaly normal !
No not normal - just a joke.
In coldstart the RPM is allways a little highter as if the car is warm. I never checked this on my C63s how it is.
That your car not move or slow move can be the wet clutch - maybe !
Make diagnosis with Xentry … check adaption values etc or something like that.
Have you this car new bought ?
Milage ?
Old Mar 27, 2026 | 08:25 AM
MK6-R20's Avatar
437 HP
Originally Posted by C63s_Jack
Totaly normal !
Milage ?
lol
Do you have any clue if it is common for a wet clutch to act like this?
I am the 3rd owner, i just picked it up this week. Its has 43.000 km / 26.700 miles
Old Mar 27, 2026 | 12:55 PM
superswiss's Avatar
2019 C63CS
Slipping of the wet clutch with the older 7-speed are fairly well documented. Wear of the clutch, old fluid, low fluid etc. can all have an impact. When was the transmission last serviced? Any idea how often the previews owners used Race Start?
Having said that, even though mine is a FL with the new 9-speed, I never move the car until the rpms have settled.
Old Mar 27, 2026 | 01:17 PM
C63s_Jack's Avatar
AMG C63s Coupe
Thats not much miles. For 2017 very little.
On testdrive nothing noticeable ?
Is the car tuned ?
Old Mar 27, 2026 | 03:10 PM
MK6-R20's Avatar
437 HP
As far as i remember the transmission never has been serviced. I’ll need to check the service history again once im home. All services are always done on time by Mercedes Dealer, i have all documents. Engine oil got changed recently.
I unfortunately dont know how many times Race Start is used since i bought the car from a local shop who got this car as a trade-in for another car.
Old Mar 27, 2026 | 03:13 PM
MK6-R20's Avatar
437 HP
Is the car tuned ?
No, didnt notice anything, however i did let the idle drop before moving when i trestdrove it. Once idle is dropped its perfectly fine.
No, Not tuned.
Old Mar 27, 2026 | 03:28 PM
superswiss's Avatar
2019 C63CS
I hope that’s not true. This transmission needs regular service. On low mileage cars like this, the service is time based. If the service was done at a dealership, then I would expect that they followed proper protocols. My car is two years younger with 40k miles, and the transmission was already serviced twice. I only drive about 4000 miles/year these days, so it gets serviced every 12 months. The rear differential also needs regular service. If I recall correctly both are due every 3 years or 30k miles, whichever comes first, but the first service of each is at different miles/years, so they kinda alternate over the life of the car.
Old Mar 27, 2026 | 03:32 PM
C63s_Jack's Avatar
AMG C63s Coupe
No, Not tuned.
Sounds good.
I would go to MB and check car with Xentry.
All we can do here is guess.
As far as i remember the transmission never has been serviced. I’ll need to check the service history again once . All services are always done on time by Mercedes Dealer, i have all documents. Engine oil got changed recently.
I cant beleve but nothing is unpossible says toyota.
Make a double check of service history.
Transmission 3 Years or 50.000 km
Spark plugs 3 Years or 70.000 km
Diff 3 Years or ??.??? km
Miles dont interesting with your low milage.
I dont think the missing transmission oil change is the problem ( but who knows)
i would guess something is worn … maybe the wet clutch but only a guess.
Old Apr 6, 2026 | 02:51 AM
C63s_Jack's Avatar
AMG C63s Coupe
@MK6-R20
Some new insights ?
Old Apr 6, 2026 | 09:37 PM
MK6-R20's Avatar
437 HP
@MK6-R20
Some new insights ?
Honestly, not really. Its weird, but it changes from day to day. Some days on cold start with slighty cold weather the issue is still there, other days on a cold start with warmer weather the issue isnt there.
I just got my battery replaced, since the old one was dying, i will check tomorrow if that has helped, even tho i dont know if the battery would have any affect on this issue.
Old Apr 7, 2026 | 01:49 AM
Profomo's Avatar
2019 C63S Sedan
This happened to me, my car is a 2019 FL though
You can find this issue discussed in this thread: https://mbworld.org/forums/c63-c63s-...eleration.html
If it's the same thing, it's your wet clutch that needs replacing
My issue is similar to yours, on start up it requires some throttle for the car to actually start moving. It started out just being a little bit of throttle every once in a while - progressed to every time on start up r requiring a lot of throttle and having a huge thunk to get into gear.
Don't want to scare you, but after what I've been through I would not sit on this issue. I'd go get it addressed as soon as you can.
Old Apr 7, 2026 | 02:13 AM
C63s_Jack's Avatar
AMG C63s Coupe
How much $$$ ?
Old Apr 7, 2026 | 02:14 AM
C63s_Jack's Avatar
AMG C63s Coupe
How much $$$ ?
Next question is # number history.
On PFL was this a common topic.
FL not so - maybe if you use race start often or abuse car with donuts burnout stage 1-3 etc.
Old Apr 7, 2026 | 02:52 AM
Profomo's Avatar
2019 C63S Sedan
How much $$$ ?
My prices may not be indicative as I'm in SEA, but for what it's worth it's around ~4.5k USD eqv excluding labor
I don't race start, nor abuse it, nor is it tuned. Think it's a combination of luck of the draw and the ****ty tropical weather taking it's toll on the car
Old Apr 7, 2026 | 06:07 AM
C63s_Jack's Avatar
AMG C63s Coupe
Okay you are from south asia - tropical heat.
M177 always sweating.
This wet-clutch is realy expensive in your country.
Transmission out & in + replace Wet Clutch untit - i do not think that this is a realy big job. i have seen YT video.
What you are doing now ?
