Don Nguyen | **Vinyl Roof Wrapping Services + Stickers/Graphics and more!**
Before:
Driver side tinted/smoked - Passenger side untinted/unsmoked.
After:
-Don Nguyen
donathon@gmail.com
-Don Nguyen
donathon@gmail.com
Some of the plastidip peeled off/up a bit when installing the vinyl. Tip of advice, plastidip the antenna after the roof is wrapped, instead of plastidipping i tbeforehand.
-Don Nguyen
donathon@gmail.com
-Don Nguyen
donathon@gmail.com
Vinyl is only an alternative to paint, it is not a replacement. However, in this case, it was a cheaper option and better than leaving the roof to oxidize further. The better condition the roof is in, the better the final results of the vinyl wrap will be. The vinyl material is very thin, about the same thickness as the car's paint, so it is by no means a body filler. Luckily for the owner of this car, even though the roof was in pretty bad condition, the vinyl was able to hide/cover up most of the oxidation without showing through the vinyl itself.
We went with the gloss black vinyl finish for the roof to give it a more factory look, versus going with the matte black finish or carbon fiber finishes.
Before:
After:
-Don Nguyen
donathon@gmail.com
-Don Nguyen
donathon@gmail.com
Before:
Right - Passenger side tinted / smoked:
Before - Untinted / unsmoked:
After:
-Don Nguyen
donathon@gmail.com
I had this white Mercedes Benz C63 AMG sedan come by to have me vinyl wrap the roof of their car in my gloss black material to give it the panoramic roof look. I believe the owner of this car was from Los Angeles and drove out to me in Orange County / Anaheim Hills to have the work done. I also did the side front bumper slats in the matte 3M carbon fiber di-noc material, which was a bit tricky to cut, since it had to be done freehand and there were no real lines/curves to follow. I forgot to take the before pictures, but I am sure you can imagine what a white roof would have looked like on this car before I vinyl wrapped the roof black.
Blacking out the chrome in either gloss or matte black vinyl to give it the shadowline look would really complete the look of this car imo and give it an aggressive look/stance.
-Don Nguyen
donathon@gmail.com
-Don Nguyen
donathon@gmail.com
Before:
Tinted / smoked inner smaller passenger side headlight:
After:
-Don Nguyen
donathon@gmail.com
By blacking out the chrome it really makes the red calipers and other parts of the car pop more.
Before:
After:
-Don Nguyen
donathon@gmail.com
Before:
After:
-Don Nguyen
donathon@gmail.com
Before:
After:
-Don Nguyen
donathon@gmail.com
In this picture the driver side has already been done and the passenger side has been applied, just waiting to be trimmed. You can see everything is custom fitted, since I do not use pre cut materials. This allows me to cover more of the headlights than pre cut pieces do and also get a closer/better fit to the pieces that I am covering/applying the material to.
Clear headlight protective film is good if you have glass headlights, so it'll prevent rocks from cracking it or chipping it. This can also be applied to fog lights, which are more prone to cracking, since they're lower/closer to the ground. Even if your headlights are plastic, the film will help prevent nicks and chips in the plastic lenses. It'll also help protect/prevent against oxidation better. If your headlights are already oxidized/faded, I can clear/clean those up for you before putting on the clear film.
I know clear bras / clear headlight protection films aren't very exciting, so I figured I'd post pictures of this gray / silver Mercedes Benz E55 AMG's tail lights that I tinted as well. This is my lighter shade that I used for this cars tail lights. Unlike a lot of the other tail lights that I have posted recently, I only tinted the clear portions on this car's tail lights versus tinting the whole thing. So these pictures will be good to help show those who were interested in something similar for their cars and were wondering how just the clear portion would look like tinted / smoked, only slightly darkening the clear parts of the tail light.
Before:
After:
Before:
After:
-Don Nguyen
donathon@gmail.com
Before:
After:
-Don Nguyen
donathon@gmail.com
As comparison, the eyelids on the headlights are real carbon fiber pieces.
Before:
After:
-Don Nguyen
donathon@gmail.com
Before (matte roof):
After (gloss roof):
-Don Nguyen
donathon@gmail.com
Before:
Only driver side trunk tail light is tinted in this picture:
After:
-Don Nguyen
donathon@gmail.com
Everything is wrapped seamlessly and tucked in where ever possible, to provide the longest lasting results.
Before:
After:
-Don Nguyen
donathon@gmail.com
-Don Nguyen
donathon@gmail.com
-Don Nguyen
donathon@gmail.com
Before:
After:
-Don Nguyen
donathon@gmail.com
Before:
After:
-Don Nguyen
donathon@gmail.com
This was one of the last cars that I did while up there, and I was a bit excited, so I forgot to take some before pictures of it. The owner of this white Subaru STI wagon / hatch brought his car to me to have me vinyl wrap the roof of his car with my gloss black vinyl material. Subarus are one of those cars that can pull off the matte or gloss black look. Since there is no sunroof on this car, it gives it a very smooth and continuous result / look.
-Don Nguyen
donathon@gmail.com
Front splitters:
Roof spoiler:
Rear diffuser:
Roof:
Side pillars:
-Don Nguyen
donathon@gmail.com
