TPMS won't work w/ chrome wheels?
2015 S550, 1988 560SL
Tire pressure monitor sensor won't work w/ chromed wheels. That's what the dealer is telling me. The wheels are the original AMG 18". I had them chromed and had the dealer mount them so they could recode sensors. I drive ~ 1 mile and the TPMS errors out; "Visit Workshop." Dealer's solution is to turn off the system. Has anyone heard of this or had a similar problem? It sounds like BS to me, but I'd like to know for sure.
Mine are chrome and although the sensor recently croaked, it had worked without a problem for the previous 5 months.
I'm waiting (only 3 weeks) for the new module to come in and then it will work again.
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Metallic contact between the sensor and the wheel can impair the function. If the car can not "hear" all four sensors you may get this kind of a message.
(Provided that all sensors has never been switched off or forgotten to be switched on. This is done using a LF inductive hand-tool)
You can make one simple check yourself: Using an Ohm-meter, check for electric contact between the nozzle (metallic tip) and the wheel. If there is contact, you may have to replace the gasket)
is a ///AMG badged CL500.
Yeah, i have the same problem with my car. 2002 CL500. i have the chromed 5 star monoblock. most likely the same rims you have. and after a mile, it triggers the sensor, and tells me to visit workshop. i just keep resetting it. i hope it doesnt cause any damage. my agent told me i just need to add more air. i havent done it yet. it fluctuates from 29-30-28-29 from time to time.
