CL-Class (W215) 2000-2006: CL 500, CL 600
links installation, help request
Old Feb 11, 2007 | 01:39 AM
amgluvr's Avatar
is a ///AMG badged CL500.
planning on purchasing a set of links from adjustableairirde.com. does anyone know any local shops or person who has experience with the links installation? any help is greatly appreciated.
Old Feb 11, 2007 | 08:52 AM
tkracing's Avatar
2003 CL55 stage 4 Renntech and 2006 CLS55 AMG
I would recommend a lowering module. Renntech or Carlsson. I see more people who have had the modified links switch to the module including myself.
Old Feb 11, 2007 | 09:55 PM
herzog racing's Avatar
CL500
Question
why
Old Feb 11, 2007 | 10:43 PM
tkracing's Avatar
Originally Posted by herzog racing
why
Modified linkage does not tell the computer on how much compression (air pressure) to either increase or decrease to compensate for ride quality. Giving the vehicle a different ride as well as possibilities of damaging air hydrolic suspension (not to mention front fenders). Very expensive if not under warranty and if the dealership finds out its on Modified links they probably will try to get out of it.
Old Feb 25, 2007 | 11:41 PM
John V.'s Avatar
Former Vendor of MBWorld
2007 CLK63 Cab
How do you think the dealer would react with a module in there especially if it was one that you had to cut wires to install??? The system is actaully not air pressure aswell. Its hydraulic. Module's just lower the vehicle by changing the voltage comming from the sensor to the computer. The only other thing they do is not lower the vehicle that fraction of an inche at high speeds.
Have had my links in for years with absolutely no problem.
Old Feb 26, 2007 | 12:43 AM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Unlike the links, those using the module can conveniently adjust their ride ride at any time without going underneath the car. The Renntech module also has a rotary switch that turns it off.
