CL-Class (W215) 2000-2006: CL 500, CL 600
Blinker Malfunction!
Old Apr 22, 2007 | 12:24 AM
MJ'sCL's Avatar
CL500 AMG
My blinker malfunction always pops up front left or front right, even tho i know the bulbs are good......Has this happened to any of you? Most of the time when i restart the car it is back to normal.....
Old Apr 25, 2007 | 11:06 AM
techbike's Avatar
All of them, as much as I can...
Usually, the connector at the bulb gets corrosion and the contacts go bad and intermittent.
Take it out, remove the bulb, spray with brake cleaner or contact cleaner, wipe down, re-install. Be careful and don't force it, they're easy to break. Should be good for another year.
Old Apr 25, 2007 | 05:44 PM
MJ'sCL's Avatar
CL500 AMG
Thanks alot i tried cleaning it out but not as you stated
p.s thats a beautiful Cobra.
