CL-Class (W215) 2000-2006: CL 500, CL 600
airmatic or ABC problems ... which is wackier?
Old Jul 9, 2007 | 02:04 PM
arena3's Avatar
I am curious on this as I know the beatiful CL has both systems in place standard.
The S class sedan can however be purchased with the airmatic suspension only.
Does this save a lot of headaches or is the airmatic causing most of the problems?
thanks and enjoy the icon
Old Jul 9, 2007 | 05:42 PM
v8plus4's Avatar
2024 AMG G63, 2023 Bentley GTC Speed
The CL has ABC, no airmatic.
Old Jul 9, 2007 | 09:08 PM
arena3's Avatar
well, by that logic the S class with optional ABC and standard airmatic would be the most costly to maintain.
Any thoughts please on if a "stripped" S class 550 -4 door
would be more problematic than a CL550- 2 door s class of sorts.
confusion over money matters..........
Old Jul 21, 2007 | 09:47 PM
Kar don's Avatar
Mercedes-Benz
arena3, i think you are confused on airmatic and ABC. If you have Airmatic, you don't have ABC. If you have ABC you don't have airmatic. With the S-class if you order the ABC option it REPLACES the standard airmatic, its not an add-on or additional upgrade to the airmatic, entirely different system.
Airmatic runs on air while ABC uses hydraulic fluid.
