turn signal light
2020 GLB 250 4matic
turn signal light
I have a problem with my turn signal. The other day the light bulb went out. So I changed it and it worked. After going out and getting the car back later from the valet, the light wasn't working again. I changed to another bulb but this time it didn't work. I switched the bulb and holder from the other side and it still didn't work, but the other side worked so it's not a bulb or holder problem. Does anyone have an idea what could be wrong? I hope it's not something complicated or expensive. I tried to check the fuse chart in the car but it's listed only as "electronic fuse" so I have no idea where that is or to check if it's blown. Thanks for the help.
