Twin Tail Pipes for my CL500.
I have a 2002 CL500 I want to know if there's any tail pipes I can just change on the ends so I get the quad exhausts. Don't really want to change the system or back box.
Any recommendations ?
Kind Regards
See the pic.
https://mbworld.org/forums/attachmen...4&d=1201468357
If so, you may want to check out if the dealer has replacement twin tips for your single outlet exhaust tip on each side. I know that they carry such items for the S class.
If not, then perhaps you can try your local speed shop and see if they can weld on a custom twin tip setup in place of your stock single outlet. That would be the most inexpensive solution to have the quad tip appearance without spending a considerable sum of money.
Good luck,
Jon
