CL-Class (W215) 2000-2006: CL 500, CL 600
abc
Old Apr 29, 2008 | 12:24 AM
wease206's Avatar
W215/X164/C124
abc
abc! how can you check on it on a everyday using; just to make sure that it is in a great good use when your w215 is in use and dont want to make a fool out of yourself on a friday nite with your lady
it happen to me on my range rover 5 times and i hate that when it happen
1200buck everytimes
Old Apr 29, 2008 | 09:10 AM
Vendetta's Avatar
SL65 AMG
ABC settings are "normal" and "sport" - not on and off. When set to sport, you will see that the light in the switch is turned on. You will also notice a stiffer ride.
If you're asking about ESP, that's a different story.
-V
Old Apr 29, 2008 | 10:51 AM
wease206's Avatar
W215/X164/C124
how about esp
Old Apr 29, 2008 | 11:05 AM
Vendetta's Avatar
SL65 AMG
ESP is OFF when you see the warning lamp illuminated between the spedometer and tach. It's a yellow triangle with a "!" in the middle. If this is on, and you mash the gas pedal to the floor from a standing start, you should break the rear tires free and that will prove ESP is off. (It is never 100% off, it will still function in real emergencies, but don't rely on that to save you).
-Vendetta
