CL-Class (W215) 2000-2006: CL 500, CL 600
Can I avoid most ABC problems if
Old Jul 13, 2008 | 04:22 PM
jackstefano's Avatar
2002 CL600
I don't activate the ABC "Sport" mode, or does that not make much difference since ABC is in use even when the car is not in Sport mode. It's an '02 CL600.
Old Jul 13, 2008 | 05:12 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
As far as I know, you are correct, it does not make much difference, the usual problems will still occur. The pump, valves, etc. are always in use, regardless of the setting -
Old Jul 14, 2008 | 07:18 AM
Untertürkheim's Avatar
The best thing you can do is have the system serviced regularly. Flushing out the fluids, and replacing any filters...
Old Jul 14, 2008 | 11:30 AM
reddog's Avatar
'03 CL500,& '18 GLS63. Gone: '83 500SEC,'99 500SL,'07GL450
filters
[QUOTE=Untertürkheim;2935325]The best thing you can do is have the system serviced regularly. Flushing out the fluids, and replacing any filters...[/Q
The high pressure ABC distribution hose was recently replaced under warranty on my 2003 CL500. The mesh width of the new filter was "3" microns instead of "10" microns in the original filter. The revised 3 micron filter entered series production as of October, 2005. Check with the MB parts dept. for specific applications. Part: 003-184-61-01. List price-$42.
Old Jul 15, 2008 | 01:47 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
I have used ABC sport 98% of the time since '03 and it has been flawless. It makes no difference.
Old Jul 15, 2008 | 08:42 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
How often should you service the filter and system?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 30, 2008 | 02:04 AM
onelightmind's Avatar
s65
my german mechanic said it doesn't matter. Save your cash for busted hoses and shut it down soon thereafter so you don't burn the pump... blown 4 hoses
Old Aug 10, 2008 | 01:39 AM
Angel 430's Avatar
How often do you have to servise the system?
