CL-Class (W215) 2000-2006: CL 500, CL 600
ABC System
Old Aug 10, 2008 | 01:44 AM
Angel 430's Avatar
ABC System
Can anyone please tell me how often I have to service the ABC system. Change the fluids and filters and whatever else that goes with it. Or would it better to drive and let it break down completely and then replace?
Old Aug 10, 2008 | 02:19 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
There is no service interval for the ABC system.
MB now recommend that the oil is filtered and reused rather than replacing it.
The old type oil filter for the ABC system was 10microns, the new one is 3 microns. I would replace the filter with the newer type, but I wouldn't worry about doing anything else to the system (changing oil, etc).
Old Aug 10, 2008 | 11:15 PM
Angel 430's Avatar
the CL500 was recalled for something in the ABC. I took it in and they replaced it, is this what they did or did they replace something that had nothing to do with the filter?
Old Aug 11, 2008 | 05:53 AM
Ausmbtech's Avatar
The recall was for a hose replacement, it has nothing to do witht the filter.
Many people don't even realise there is a filter. It is located in the ABC oil bottle. Take the cap/return line fitting off and you will see it attached to the underside of the cap.
It can be easily done yourself.
Old Aug 11, 2008 | 08:58 PM
Bo CL500's Avatar
CL500
So the ABC oil never has to be changed? Do you know how much the filter is and is it worth doing or it doesnt really matter?
Old Aug 12, 2008 | 07:53 AM
Ausmbtech's Avatar
Personally, I would just leave the system alone.
If there is any reason to perform any work on the system then I would change the filter.
