??????ODB II INFO?????? CL600
Which code scanner/reader writer (USB/Serial) will work for gathering real time system data and also writing?? Does it need to have the special MB connectors or will the ODB II cable do??? If one of you tuners could step up and make some suggestions and explain the whole deal, I would appreciate it immensly.....
I use the Equus Innova 3110 OBDII tool. It connects to the standard OBDII port under the dash. I have to say this tool has helped me immensely. It does display feeeze frame data which is essentially stored sensor data from all the OBDII health check programs. Nothing live though. Their 3130 model does display liva data.
Link to the data page:
http://www.iequus.com/product_info.p...gory_id=1_10_7
I bought mine from Amazon for about $120.
Keep in mind that all the OBDII tools only get you basic OBD info. For the cool Benz stuff, you still need Star Diagnostics.
If you still want software instead of a tool, I'm sure someone else will chime in with some suggestions.
