CL-Class (W215) 2000-2006: CL 500, CL 600
CL600 Wheel removal???HELP
Old Nov 30, 2008 | 12:09 PM
teckersley's Avatar
CL600
I posted this on the wheel tech thread too but not much luck.
I have a flat tire and I cant seem to get the wheel off the car. I loosened and removed all 5 bolts but I cant get the wheel to break free from the car. Is it like normal cars where it should just pull off or is there something special that needs to be done? Sorry for the ignorant question but this is my first time and the manual doesn't say anything other than loosen the bolts and insert the alignment pin. Is there something else that needs to be done? I don't want to mess anything up.
Thanks for the help.
Old Nov 30, 2008 | 12:52 PM
fatmike's Avatar
CLK63 BS
It's probably just stuck on, first make sure the car is on jack stands and a sturdy jack, then give the wheel a few kicks.
Old Nov 30, 2008 | 12:58 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
If that does not work, lower the car gently, with the wheel bolts removed, and you will find that the wheel becomes loose from the pressure of the weight of the car.
I use a small hydraulic jack, and it works fine.....
Old Nov 30, 2008 | 07:26 PM
brokenstunter's Avatar
2003 CL500
mike, its common. its just stuck. like calgary said make sure its on sturdy blocks/stands and kick it from the inside out. Have someone to catch the wheel though!
Old Dec 4, 2008 | 12:53 AM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
hit the tire wtih a rubber mal.
Old Dec 4, 2008 | 12:44 PM
teckersley's Avatar
CL600
i got it off. it was just stuck. Wanted to verify I wouldnt mess something up.
thanks for the help
