CL-Class (W215) 2000-2006: CL 500, CL 600
Spark Plugs
Rating: Thread Rating: 3 votes, 5.00 average.
Old Jan 22, 2009 | 11:32 AM
Bo CL500's Avatar
CL500
Spark Plugs
Can someone guide me through on how to change the spark plugs? Thanks
Old Jan 23, 2009 | 03:12 PM
wease206's Avatar
W215/X164/C124
removed cover
removed coil nuts
unplug coil to spark
total of spark is about 16
8 on each side
if you know have the tool
is be little harder to removed spark plug wires
good luck 2.5 hrs and 6pk beer you be okay
Old Jan 24, 2009 | 09:27 PM
~CL500~'s Avatar
E90 N54 & W251
+1
That pretty much sums it up. The rears are pretty difficult due to space constraints. Also, make sure you snap in the spark plug connectors correctly when reconnecting everything. They need a hard wiggle and push. I rechecked mine like 6 times and was still finding some that were loose. Good luck!
Old Jan 26, 2009 | 11:21 AM
Bo CL500's Avatar
CL500
Originally Posted by wease206
removed cover
removed coil nuts
8 on each side
I cant figure out how to take the coil out.
Did you ever take the center consoul out and connect ur ipod to it?
Old Jan 26, 2009 | 02:48 PM
wease206's Avatar
W215/X164/C124
you have to unscrew the nut out that hold coil follow the plug
the plug will lead you to the spark plug
this is the tool to use to removed the plug wires
http://www.zdmak.com/spark-plug-tool.asp
http://www.technictool.com/mercedes.htm
if you dont have you a L shape Pliers
hope this help
as for the ipod i have not removed it out yet because it been
snowing alot here
Old Jan 26, 2009 | 05:21 PM
Bo CL500's Avatar
CL500
hope this help
snowing alot here
I must be an idiot because I still can't see where you take the nut out the coil, would you happen to have any pictures? My car is a 2001 and has 45K miles, should I even change them yet since its so old or should i wait till 100K. either way i still need to know how to do it.
Old Jan 26, 2009 | 05:52 PM
wease206's Avatar
W215/X164/C124
THE COIL PACK THERE SHOULD BE A LITTLE NUTS STAR SHAPE LIKE
I THINK IS EVERY 100K OR 5YRS WHATEVER COMES 1ST
LATER WHEN I GET HOME I SEND YOU A PICTURE
WHAT IS YOUR EMAIL AGAIN
Old Jan 26, 2009 | 05:56 PM
Bo CL500's Avatar
CL500
thanks man....... bomilkovvv@yahoo.com
Old Jan 27, 2009 | 12:39 PM
wease206's Avatar
W215/X164/C124
here is the picture of the coil the little hole is where the star shape nut located at
once you removed the nuts coil pack just fall out, follow the black wire from the coil will lead you to the spark plug
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
