CL-Class (W215) 2000-2006: CL 500, CL 600
UK vs US command unit
Old Feb 18, 2009 | 02:37 PM
wease206's Avatar
W215/X164/C124
Can you swap out the U.S version command and put in U.K version Command
unit?
Has anyone ever done it before.
wease206's Avatar
W215/X164/C124
2000 CL
Old Feb 18, 2009 | 02:44 PM
Bo CL500's Avatar
CL500
Originally Posted by wease206
2000 CL
i believe so. the only difference is the the UK one has an extra button for the TV. this will enable you to hook your ipod to the deck and and enable you to watch videos from your ipod and have CD quality. double check with the MB dealership, but i am 95% sure.
Old Feb 18, 2009 | 04:48 PM
wease206's Avatar
W215/X164/C124
how about the nav would it read U.S disk
Old Feb 18, 2009 | 09:58 PM
Bo CL500's Avatar
CL500
not sure, but there is no reason why it shouldnt
Old Feb 19, 2009 | 10:37 AM
~CL500~'s Avatar
E90 N54 & W251
I know a few board members swapped their US units for Euro units from MBenzNL so I would assume the disc should work. That would be a pretty big sacrifice for the TV button if it didn't.
Old Feb 19, 2009 | 12:21 PM
Bo CL500's Avatar
CL500
besides the TV botton is everything else the same?
Old Feb 19, 2009 | 02:09 PM
wease206's Avatar
W215/X164/C124
the reason why i want to swap it out because by nav is jam
i cant use DISK IS STUCK
IF I WERE TO SENT IN THE UNIT FOR REPAIR IT WOULD COST ME ABOUT 300.00 AND TO ENABLE THE UNIT IS ALSO ABOUT 399.99 WITH CABLE
i found a unit on ebay for 699.99 UK ( BUT I STILL NEED TO BUY THE CABLE 300)
DO I REALLY NEED NAV SINCE I LIVE IN SEATTLE WASHINGTON SMALL CITY
NAV NO NEED KNOW ALL THE ROUTE.......JUST WANT A WORKING UNIT
Old Feb 19, 2009 | 03:55 PM
~CL500~'s Avatar
E90 N54 & W251
If memory serves me correct, the only differences were the euro model has:
  • TV button with tuner instead of a blank button.
  • Instead of words on the buttons, pictures are used.
  • There is no auto daylight savings time adjustment.
  • Supports RDS
Old Feb 19, 2009 | 04:03 PM
~CL500~'s Avatar
E90 N54 & W251
This is really up to you.
What would I do? I'd just spend the $300 to get the CD drive fixed and call it a day. Mine get's stuck at times too. I'll be sure to PM you when mine fails. $300 beats replacing the whole unit.
I thought about adding the TV/DVD mod, but the fact that our nav screens are so small and not wide screen changed my mind. Also the TV reception will be full of static and not clear when in motion. This isn't cable or satellite TV we're talking about. Also, the tuner is not digital and analog signals will be going away soon, so DVD video would be best if you go that route.
