This wheel are valid for W215?
The sizes and offsets are fairly aggressive. 19x8.5 +25 and 19x9.5 +28, sounds like you would rub in my opinion. Unless you aren't lowered. I would find a different set to avoid rubbing, fender work, etc.
Check your owner's manual and see what the offset of the stock wheels are. Then search for wheels that correspond to that offset. Tirerack is a good place to start.
(Also, MB used to and may still publish a book called Genuine Mercedes Benz Accessories Wheels - you can get it from your parts or sales department, at least here in the States.)
The wrong offset means all adding all kinds of spacer's rings mods - life is too short.
You can have problems, like rubbing, that are constantly annoying - life is too short.
