Weird ABC Problem
Newbie here in the UK. Have a 2000 CL600 V12 Coupe and the ABC is showing a fault on the screen.
The car sits higher at the back than the front on both sides. But the front looks normal, and the rear looks lifted if that makes sense?
It says goto Workshop, I was just wondering can I read this with an OBDII scanner, reset the fault and see if it comes abck?
Any ideas what it could be or what I could start checking?
If I raise the suspension on 2 lights, the front levels out with the back. So it looks like the back 2 shocks arn't lowering as needed. They just stay at the same level?
Blocked pipes? Valve block or?
Any help please
It stayed completely up all around this morning on LED x 2 higher setting. Drove fine, just a tough bumpy for being so high.
Will get it scanned as OBDII just got the engine controller.
