CL-Class (W215) 2000-2006: CL 500, CL 600
Soft Door Close
Old Jan 4, 2010 | 01:32 PM
Bo CL500's Avatar
CL500
Soft Door Close
Can someone tell me how to replace the soft door close on the CL500 2001? Is it difficult or is it just better to take to do the mechanic?
Old Jan 4, 2010 | 10:53 PM
Bo CL500's Avatar
CL500
Anyone?
Old Jan 4, 2010 | 11:00 PM
benz_addict's Avatar
V12TT
I'm not sure what you mean by how to replace the soft door close but if it's not working then the problem is the PSE pump. The pump is located in the trunk, mounted on the left side. It should be replaced.
You could also disconnect the battery for 10-15 mins reconnect it then the soft close might work again, but not sure for how long.
Old Jan 5, 2010 | 07:07 PM
Bo CL500's Avatar
CL500
the thing is that i heard a loud pop when i closed the door one time from the door, and now i hear a sound coming out of the door as if air is coming out of what ever is in the door, so this is what needs to be replaced i thing. is that pump in the door easy to replace? or i still need to mess with the thing in the trunk?
i did disconnect the battery cuz someone else told me to do it, but nothing, so this is why it think its something in the door that has to be replaced.
Old Jan 5, 2010 | 11:56 PM
CoupeLeicht600's Avatar
Yes!
Are you referring to the pneumatic door and trunk assist? When you close the door, the door "sucks" in gently?
If that's the case, I would go to a mechanic. It is located in the trunk but you don't want to be messing with that powerful battery. I had the same issue, but after going to the dealer, he messed up up central locking system. Fortunately, it was their fault so he didn't charge me for the mistake and gave me a decent discount on the pneumatic issue.
Old Jan 6, 2010 | 02:22 AM
Bo CL500's Avatar
CL500
yes thats what i am reffering do. how much did it cost u?
Old Jan 6, 2010 | 05:32 PM
awiner's Avatar
2003 CL55 AMG
You need an entire new door lock mechanism. What happened is the plastic end cap has broken and popped off the pneumatic system on the door lock thus allowing the air to escape.
I just had to replace mine and had the same loud bang and subsequent whoosh as well. The whoosh sound tells you that your PSE is working
The white plastic cap holds the pneumatic diaphragm back under strong spring pressure. The sad thing is that MB could have made the plastic body cap on the unit 1/4" thicker and it would have lasted 2x longer. There is no replacement part for the cap, however, after looking at the part it may be possible to epoxy the cap back into place.
This is a common problem that usually happens after 7 years or so. Probably also depends on use (door closes).
The replacement is substantial. The door panel, inner door insulation, outside door handle, rear front door speaker, keyless go antenna (if equipped), inner and outer front window seals, as well as the front window and regulator need to come out in order to get the door locking unit out of the door frame. The unit is quite large (approx. about 1' long by 6" wide.). I had a friend who is a full time local MB tech help me with the repair and it took about 4 hours.
The part # for the Drivers side (left) is A2157201335 .. Passenger side (right) is A2157201635.... Price is about $650.00 for a new unit.
You may want to verify part #'s with your MB parts counter. My part #'s reflect the door locks for a 2003 CL. I would assume, however I know better than to assume, that the part #'s are the same for 2001 - 2005. Best to verify though.
Looks like this:
Old Jan 6, 2010 | 07:33 PM
Bo CL500's Avatar
CL500
so its better for me not to mess with it if im not a proffesional?
Old Jan 6, 2010 | 08:09 PM
awiner's Avatar
2003 CL55 AMG
If your not competent in how the door panel and other related pieces come apart, I would leave it to someone who has experience in that area.
If you are willing to tackle the task, make sure you trace where the window fits into the regulator with a sharpie. Makes getting the window alignment easier.
Old Jan 8, 2010 | 04:21 AM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
just happened on our cl500, driver's door. $650!!! damn
Old Jan 12, 2010 | 08:53 PM
Bo CL500's Avatar
CL500
where did u take it
Old Jan 12, 2010 | 10:14 PM
gaazmon's Avatar
where did u take it
haven't gotten it fixed yet
Old Sep 12, 2012 | 04:12 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Alas, this has just happened to me
At least we have awiner to give us the details
Old Sep 13, 2012 | 04:20 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Post a "how to" when you do the repair OCKlasse.
R.K.
Old Sep 13, 2012 | 08:15 PM
OCKlasse's Avatar
MBworld Guru
R.K.
OK
Old Sep 13, 2012 | 10:58 PM
awiner's Avatar
2003 CL55 AMG
And you can now find the repro replacement parts so you don't have to buy a while new $600 unit.
http://www.cart.com.au/mono-global/view/2606
Old Sep 13, 2012 | 11:55 PM
OCKlasse's Avatar
MBworld Guru
Damn! Already bought a used unit. Oh well, I probably would not have wanted to wait on the shipping time.
Old Sep 14, 2012 | 08:38 PM
mf219's Avatar
2004 CL500
this problem (along with trunk opening problem) can often be fixed without buying ANY parts. sometimes all ya' need is some glue and/or some tape
Old Sep 14, 2012 | 09:54 PM
awiner's Avatar
2003 CL55 AMG
Yes, that commonly works too.
Old Sep 16, 2012 | 05:19 PM
zneB-sedecreM's Avatar
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
Great, informational post!
Looks like this:
Old Sep 19, 2012 | 11:44 AM
rbanna's Avatar
2007 CL500 W216
Check this...
Hi, this was happened to me before, after long time of checking I have just disconnected the battery and after 10 mins connected again, then I got the soft clos function working again, just try this before chnging any parts,
Bye,
Rami
Old Sep 19, 2012 | 02:12 PM
awiner's Avatar
2003 CL55 AMG
Bye,
Rami
Your method works if the PSE circuit on the Pneumatic Pump is going bad/becoming weak and has de-actiavted itself from the loop due to time out issues. The way you know if you have a blown soft close issue is that you will hear a big whoosh of air in and around the latch when the pump activates attempts to do its job.
Old Sep 19, 2012 | 09:26 PM
Twins05's Avatar
S430
Thumbs up
This is a very good information . I ordered a Kit from the WEB Seite for my s 430 .
Thank you
