2000-2002 CL600 Common Problems
If you have owned one of these vehicles and have had problems with it, I would like for you to reply with an explanation of your problem in the following format:
1. What problem did you have?
2. How was this problem detected?
3. Why did this component fail? Please describe the root cause of the issue, such as a design flaw in the component, damage from road debris, etc.
4. Is there a revised component that prevents this from happening again? For components that have a design flow, has M-B issued a revised component to permanently fix this? Is it subject to a recall?
5. How do you fix this? Please include as much information as possible including the repair process, part cost, labor cost, etc.
Your input will benefit the forum as a whole. Please help to build this knowledge base on the 2000-2002 CL600.
With depreciation in mind, there are very few cars out there with this level of performance, luxury, and looks than can compete with the CL. You can get a bargain on a used one but prepared to spend unhesitatingly .
