oil leak
It would probably be hard to reroute and put in an external cooler. The 2 hoses on top of the cooler are breather lines. The oil enters and exits through the bottom, you can see where in the pictures of the engine with cooler out.
Another issue with relocating is there is coolant that runs under the cooler too. Better off replacing it or making your own gasket. If you make your own gasket I would recommend putting the cooler in water and running air into to test for leaks. It would suck to do all that work and it still leak. Getting a new cooler is safe bet. I have never heard of the new cooler leaking again but that's not saying it hasn't happened.
It is a long tough job. It was many years ago when I did this but I remember the exhaust manifold on the drivers side being hard to reach, you need swivels and many extensions.
The other main thing I can remember is cam gears. Those suckers are spring loaded, if you take the bolt out of it watch out, it will fly across your garage. Mercedes has a special tool to remove and reinstall cam gears. I made my own tool but it took time to come up with something.
There are a type of dowel pins for the timing cover that were complicated, can't remember exactly but on drivers side you need to find a bolt to screw into the pin so far it hits the end of the cylinder head and the force backs the pin out of the head.
When you have it apart you will probably notice several vacuum hoses are brittle, replace them all with some new rubber tubing.
Your local Mercedes dealer should be able to hook you up with torque specs when putting back together.
I took notes on all this but moved 3 times in the last few years so who knows where they ended up
Oil Cooler/Intake/Exhaust Replacement Torque Specs
Ready to replace the cooler with a new one ($400) from Mercedes dealer in AZ.
Do you know the recommended torque pattern and specs for all the critical stuff? We already have the head bolt info.
Also, is silicon sealant used on the cooler?
Thanks,
Brett
2002 CL600 130K miles
Thanks,
Brett
Alright, I will attempt to revive this tread too. In everyone's attempts to do this, have you found that we could simply remove the head bolts and slide them back just enough to remove the oil cooler? Bypassing the need to remove the timing chain and exhaust manifolds from the cats?
OAlternatives to TCU replacement
If he did keep it powered up, the TCU may need to "relearn" the characteristics of the renewed engine and the way you drive. If the car doesn't move the TCU is shot. If is shifting strangely, I'd drive it around for awhile so it "relearns" your driving habits and that of the renewed engine.
Just a thought.
#32
Do you have any idea oil cooler gasket together with oil cooler whic one having insid
Here are some pictures when I tore my V12 down last winter. !FUN, FUN, FUN! If anyone attempts to do this on their own, as I did, I'll be happy to give some tips and tricks on how to make the job a little easier and less painful.
Expect 30+ hours to do this from beginning to end
