Powerchip, Exhaust, and intake Questions + pics of my 2003 CL55 AMG with recent mods
OEM Designo rear roof spoiler and trunk spoiler
AMG Eurosport 20" Wheels
The cars been lowered
Painted my calipers yellow with the AMG signs visible
8000k HID headlight bulbs and Fog lamps
Removed resonators
I have some simple questions I've been searching this forum for days and can't get the answer im looking for. I want to get the Powerchip Performance ECU Upgrade, and K&N Drop In filters, a custom exhaust starting from the headers 3" straight piping to an X pipe then to stock AMG Mufflers. Is this a good setup to run? Will doing 3" straight piping give me much more power considering i will be chipped? I really appreciate if someone can help me out on this one. What is the best custom exhaust setup to have to make the most power?
Thank you
As for th ECU tuning I'm going with Speedriven. They seem to be a good fit for what I want.
Good luck!
Removed resonators
Thank you
I think the K&N filters are a good simple upgrade, and they eliminate the need to always buy new paper filters. Especially on the forced induction models that use a MAP instead of MAF, there is no chance of fouling the sensor.
Also what measurement are you at from from the ground to top of the wheel arch when you are at the lowest setting ? Front and back please
Thanks man, looks great !
i dont know the exact measurement, but i know it's a finger clearance all around.
Removing the muffler is a good idea (it will reduce low-end torque, but you'll never know it).
Removing the resonator is NOT. It can cause hi-way, overdrive drone...hence why its called a 'resonator'. All sound resonates.
I'm looking for an early 2000 CL55 and will prolly do muffler delete; However, not seeing any viable Intake mod. K&N panels are useless HP. Do for convenience, but that's it.
