Passenger door Lock
Subscribe
Oct 6, 2011 | 08:04 AM
maybe you guys can help me here. When I lock the car with the key fob or on the interior dash the PASSENGER door lock knob does not go down.
Same happens when the Auto Lock function kicks in at 15mph....the Drivers door knob goes down....but the PASSENGER knob stays up.
Any ideas??
Reply 0
Oct 6, 2011 | 02:53 PM
The door locks are operated by vacuum. Your issue is somewhere in the vacuum system. Lines, pump, door lock module.
Reply 0
Oct 6, 2011 | 04:05 PM
Awiner...thanks. I kinda figured that.....same vacuum/pump that raised the trunk probably?
Reply 0
Oct 6, 2011 | 08:49 PM
Quote: Awiner...thanks. I kinda figured that.....same vacuum/pump that raised the trunk probably?
The Pneumatic pump is located in the trunk. Driver side behind the paneling.
The pump has multiple circuits. One circuit for the truck, one for each door soft close, etc.
One way to know for sure is to have someone run a PSE test on DAS. It will report if any of the pumps circuits are in operative or not working correctly.
Reply 0
Subscribe
Currently Active Users (1)
