CL-Class (W215) 2000-2006: CL 500, CL 600
ABC Maintenance
Old Oct 14, 2011 | 07:15 AM
John CL500's Avatar
2004 CL500
ABC Maintenance
Thinking about doing some preventive ABC maintenance.
Does anyone have a diagram of the hose layouts for the ABC system?
Old Oct 14, 2011 | 08:01 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Have a look, John...
https://mbworld.org/forums/3143381-post12.html
http://www.benzworld.org/forums/w215...seconds-3.html
Old Oct 14, 2011 | 08:20 AM
John CL500's Avatar
2004 CL500
Thanks Jud.....
WOW that is A LOT of hoses!
Old Oct 14, 2011 | 08:51 AM
Jud Chapin's Avatar
Originally Posted by John CL500
Thanks Jud.....
Yes it is. What kind of maintenance are you planning on doing?
Old Oct 14, 2011 | 09:11 AM
John CL500's Avatar
2004 CL500
I was going to start with hoses. Inspect and replace if necessary.
Old Oct 14, 2011 | 11:27 AM
Jud Chapin's Avatar
Let us know how you make out. As you may know, there was a recall on one of the hoses so make sure yours has been replaced. If you're not sure, call
800-for-merc and after you provide them with your VIN, they'll be able to tell you.
Old Oct 14, 2011 | 01:21 PM
saintz's Avatar
GL450
Check the dampeners, too.
So if the hoses haven't been replaced under recall, and the car is out of warranty, they will replace them? Or is it not a true recall (i.e. must be under warranty)?
Old Oct 14, 2011 | 02:01 PM
Jud Chapin's Avatar
One hose is under recall and should be replaced by MB at no charge regardless of warranty status.
