Brakes swap .. AGAIN
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
I only say again because I assumed that there are many posts about swapping brakes on the W215 but surprisingly I saw very few incomplete ...so there is my issue ..on a CL600 ( 2004 ) .. shouldnt the swap be easy , using calipers with or maybe without rotors from a CL65 , or S65 .. the eight pistons ones ?
any other parts needed , special brackets .. I am assuming that there will more parts needed using ones from a W211 or R230 ..but the AMG ones from a AMG W215 Chassis or a W221 should be straight forward , right ? The AMG ones on the CL65 I think they are 380X34 mm correct ? is it the same for the S65 W221 ? do they use the same Calipers ? Anyone has part numbers ? Any guidance is truly appreciated . Thanks
