CL-Class (W215) 2000-2006: CL 500, CL 600
Un-Even ride height
Old Jul 20, 2012 | 06:32 PM
MB 500SL's Avatar
500 SL
Un-Even ride height
Hi Guyz
My 2003 Cl500, is higher at the front end compared to the rear, quite a noticeable difference, checked the ABC fluid - level is good, operated the button on the dash to raise and lower the car - works fine, bur still the car is higher at the front compared to the rear, i have no ABC messages on the instrument cluster, car drives fine,no visual leaks, no issues, Only uneven height.
Only one thing which i feel is abnormal, when i start the car i hear this sound from the driver side for like 2 secs and then goes away.
Any help appreciated.
Thanx
Old Jul 20, 2012 | 06:46 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
You forgot to mention your reference, measurement point in order to make that statement.
Didn't you notice this when you bought it 2 weeks ago?
Old Jul 20, 2012 | 08:51 PM
awiner's Avatar
2003 CL55 AMG
Assuming your ABC valve blocks are working correctly and your front to rear wheel/tire sizes are matched, it sounds like your may need a right height optimization which is accomplished by using the Mercedes Star Dias System (SDS).
Old Jul 21, 2012 | 04:23 AM
MB 500SL's Avatar
500 SL
Thanks for the reply guys
As far as reference is concerned, My cl is running on 17inch 225/55 all around, parked the car on level ground, took the gap measurement between the tire and fender.
And Yes i did notice the difference at the time of purchase, But was more concerned with the operation and leaks.
- So i need to hook-it up with star, will look into it and report back
Thanks Again
