CL-Class (W215) 2000-2006: CL 500, CL 600
Flash warning tone
Old Nov 8, 2012 | 02:54 AM
Jay Kay's Avatar
CL 600
Flash warning tone
Hello
I find that while driving, I will come accross a bump in the road and while going through it, there is a tone and red waring that will flash on the cluster. On closer inspection, it seems that it is triggered when the suspension load is off of the car, ie; when the rear end of the car is lifting.... Any one have this problem? Or any idea on a fix?
Old Nov 8, 2012 | 09:38 AM
biker349's Avatar
cl600
possible strutt problem. is it a red abc system light?
Old Nov 8, 2012 | 12:42 PM
awiner's Avatar
2003 CL55 AMG
Do you show any malfunctions when this happens ?
If so, you need to have the codes that are being thrown to properly diagnose the issue.
If it is only a tone, my guess is pressure is getting low in the ABC system but restores itself bore a code is thrown.
Old Nov 9, 2012 | 03:09 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Mine does this when I hit a big bump, but I am also pretty low.
I think when the car is at that high point, the low pressure within the system triggers the light. A false alarm if you will since it immediately goes away once the car comes down again.
Old Nov 9, 2012 | 03:22 AM
Jay Kay's Avatar
CL 600
There is a red flash on the cluster, but it is so fast that I cant read it. The car then continues normally....
Old Nov 9, 2012 | 12:09 PM
awiner's Avatar
2003 CL55 AMG
If there is a red flash, a code has been stored.
