CL-Class (W215) 2000-2006: CL 500, CL 600
Engine Starter Relay?
Old Jan 15, 2013 | 06:55 AM
Jumbojim's Avatar
Mercedes CL500
CL500 / 2002
My ignition key will hold over in the starting position, which suggests that authority to start has been given, but 9 times out of 10 the sarter motor does not run, so no start. When the starter does turn the engine starts immediately and runs perfectly. Is there a STARTER RELAY somewhere in the fuse boxes that may need replacing?
Old Jan 15, 2013 | 12:10 PM
awiner's Avatar
2003 CL55 AMG
Could be your crankshaft position sensor is starting to go out.
Old Jan 15, 2013 | 12:37 PM
Jumbojim's Avatar
Mercedes CL500
Must be something else, as I have just changed that and the brake pedal switch.
Old Jan 15, 2013 | 12:42 PM
Jumbojim's Avatar
Mercedes CL500
The point to notice is that the starter moter does not turn at all while the engine is miss- behaving. But that the engine starts well as soon as the starter moter agrees to turn.
And I do have a new fully charged battery.
The car just sits there quietly with the key held in start and nothing happening, then after 4 or 5 attemps it roars into life.
Very strange!
Old Nov 4, 2013 | 09:43 PM
ejuni000's Avatar
04 CL 500
Jumbojim, I am having a similar issue. Did you get yours fixed?
Old Nov 24, 2013 | 02:27 PM
bruce hartwell's Avatar
clk55 amg
I am also having a similar problem. I have a good car battery and new batteries in the ignition key. Is there a relay that may be the cause?
Old Nov 27, 2013 | 06:56 AM
tusabes's Avatar
Mercedes
EIS
