CL-Class (W215) 2000-2006: CL 500, CL 600
Rear end clunk
Old Mar 29, 2013 | 01:41 PM
huesey1974's Avatar
CL500
Rear end clunk
Hi,
I have noticed that when I hit speed bumps or bigger bumps in the road I have a clunk/thud coming from the passenger side rear(uk). My mechanic had a look and says all the arms look ok. There are no ABC warnings and apart from the front sinking a little over a few days it seems ok.Any ideas on the noise and what would be most likely. I bought really cheap as a project car knowing that it needs some work and can do most things myself. Any help appreciated.
2001 CL500.
Old Mar 29, 2013 | 03:12 PM
slonar21's Avatar
CL600 2003
Could be the top of the struts that are loose, to acces you need to remove a panel on the side above rear seats (never did this myself though)
Old Mar 29, 2013 | 03:36 PM
huesey1974's Avatar
CL500
Hi,
Thanks for your reply, I tried that earlier and they were tight.
Old Mar 29, 2013 | 04:01 PM
slonar21's Avatar
CL600 2003
Check your spare tire, make sure all is secure and tight.
Old Mar 29, 2013 | 04:03 PM
huesey1974's Avatar
CL500
Done, Still the same.
Cheers
Old Mar 29, 2013 | 07:38 PM
awiner's Avatar
2003 CL55 AMG
Check your rear sub frame bushings as well. You can see if they are collapsed or not.
Old Mar 30, 2013 | 08:57 AM
huesey1974's Avatar
CL500
Hi,
Are they really big bushes? I had the car up and all the small bushes etc seem fine.It looked like one of the large bushes(the one nearest the front of the car) was cracked but not sure if it just looked like this due to the car being jacked up.Also should you be able to twist the strut on its bush very slightly by hand?
thanks
Old Mar 30, 2013 | 10:13 PM
awiner's Avatar
2003 CL55 AMG
Originally Posted by huesey1974
Hi,
thanks
The rear sub frame bushings are located at the rear end where the rear sub frame attaches to the frame. This is where you are hearing noises so it is worth checking.
If your have cracked or torn bushings on the suspension components (as you stated), it is time to replace.
Old Apr 4, 2013 | 03:17 PM
huesey1974's Avatar
CL500
Hi,
I took off the parcel shelf panel and sat in the back whilst my wife drove over a bump road and the knocking is defo coming from the top mount area.Can this be replaced or is it a full strut required?
Old Apr 4, 2013 | 10:18 PM
awiner's Avatar
2003 CL55 AMG
Hi,
Did you first try tightening the strut tower/supports to see if this fixes your issue ?
Old Apr 5, 2013 | 11:40 AM
huesey1974's Avatar
CL500
Hi,
Yes and they were tight, However today I fitted some new rims and noticed that there is some fluid around the strut area so looks like the strut may be done.
thanks
Old Apr 5, 2013 | 12:19 PM
awiner's Avatar
2003 CL55 AMG
Hi,
thanks
Leaking struts are a very well know issue
