2000 Cl500 Radio or climate control not turning on now
2000 cl500
Ok.. heres the story.
I bought the car as a repo and it had several problems, thanks to the benz forums i had everything fixed including the radio cd changer and all that.. Climate control worked perfect.
Well i had to replace the Yaw sensor which i thought was under console from which i guess is on the newer years.. Long story short here is my probblem...
I removed the console.. everything worked perfect.
I replaced everything all plugs and wire but one. it is a blue two wire plug. but cannot find anywhere it would plug in. so im assuming it is to another option my car didn't have. After reinstalling everything my command comes on but nothing is recognized and the climate control does not light up. as well as the instant mileage doesn't work. and when scrolling through cd changer and nav on dash it just has dashed thru them.
Does something have to reset or is there a fuse that could blown. or did i fry a SAM....
any info would be greatly appreciated.. especially if that two wire small plug is supposed to go somewhere..
Thanks, Justin
Thanks, Justin
