CL-Class (W215) 2000-2006: CL 500, CL 600
Help! Car won't start
Old Nov 7, 2013 | 05:38 PM
bigintruder's Avatar
2001 CL600
Hello, I own a 2001 CL600. The engine spins but the car won't start. It has done this in the past but it eventually started. This time it won't. I checked the codes and got the following: P0335 crankshaft circuit malfunction, P0341 camshaft sensor A bank 1 ckt range/perf and P0340 camshaft sensor A bank 1 circuit malfunction. I have replaced both the crankshaft sensor and the camshaft sensor however the car still won't start. When I push the valve stem on the fuel rail a get strong stream of fuel. Is there any way to check to see if the coils are firing short of removing them? Do any of you have any suggestions?
Old Nov 8, 2013 | 01:12 AM
TwinTurboTim's Avatar
2006 CL65
I would guess the reference voltage is getting pulled down. Check all 3 wires for the cam or crank. One should have 5v, then pulsed 5v, and ground.
Old Nov 8, 2013 | 12:08 PM
2001 CL600
Thanks for the response. Are you saying that I should check the 3 wires that go into the crankshaft and camshaft position sensor connectors?
