CL-Class (W215) 2000-2006: CL 500, CL 600
cl500 transmission slip
Old Dec 10, 2013 | 11:51 PM
besha.k78's Avatar
2004 CL500
Unhappy cl500 transmission slip
Hi guys any of you had chance to come across that transmission get in gear but as much you push on gas paddle it does not want to go and slowly accelerate ,can you tell me is it transmission going bad or it something else.Thank you
Old Dec 11, 2013 | 02:35 PM
dtohio's Avatar
05,cl65;33ford3wc.
Sounds like its in limp mode, which is a safety restraint built in. I would get evaluated now. Dealer is probably needed.
Old Dec 11, 2013 | 05:41 PM
lloyds's Avatar
2004 CL500
your car has the 7 speed transmission same as mine which came out in the 2004 car. I had a similar problem with mine and it is the valve body going faulty within the tranny. Sticking in a high gear or going into limp home mode until you restart the car and all is then temporary reset. Take it to a dealer or good indy and have the tranny fault codes checked, its the only way to find out for sure, worst case as I had is a new valve body.
good luck
Old Dec 15, 2013 | 07:07 AM
tusabes's Avatar
Mercedes
Could also be a bad electronic accelerator pedal
