CL-Class (W215) 2000-2006: CL 500, CL 600
Unhappy 600tt - electrical gremlins
Old 03-01-2014, 06:38 PM
Sshenton1975's Avatar
SL500
Hi All
I have a 05 CL 600 biturbo. The dreaded gear shifter issue rose its head the other day leading the car to be difficult to get out of park.
Decided to fix it my self which meant takng out whole centre consol and disconnect everything
Put it all back together and at he time i think all was well
Been away all week and came back to a decharged battery. Put a starter pack on the battery and had two issues when the car started:
1) climate control unit is dead - no lights, no nothng
2) engine fan seems to be running constantly (switches off when ignition is off)
3) speedtronic go to dealer alarm (did find a disconnected distronic lead on back of console when i took it ou second time to check. Reconnected but warning still comes on
Ive checked fuses but all seem ok. Also took console out again to see if any wires off. All ok (ac unit has jst one multiplug?)
Cant decide if its something ive done when unit was out or if it could be caused by flat battery. Just surprised that ac unit is completely dead.
Any ideas??
simon
Old 03-03-2014, 02:49 AM
tusabes's Avatar
Mercedes
Sounds like you dislodged or damaged something during console removal
Old 03-03-2014, 04:55 AM
gmphertford's Avatar
S Class
Charge up battery and re.check, Make sure all plugs are in correctly and that there is none that u have not plugged in, the fan will run if ac unit not working.
Quick Reply: Unhappy 600tt - electrical gremlins
