CL-Class (W215) 2000-2006: CL 500, CL 600
ABC warning quick red flash when hitting bumps
Old Mar 3, 2015 | 03:25 PM
BadaBingMan's Avatar
2012 CL63 2015 Tesla Model S 1963 Lincoln Continental conv 1975 Pontiac Grand Prix
Hey guys I have a 2003 CL500. when I am on the highway and hit a bump the info center turns red for barely even a second and then its back to normal I am not getting any codes. I used my rapid fire setting on my cellphone camera and was able to see its saying "check abc" or something like that. any idea on what is wrong and if i need to replace a sensor. Thanks all
Old Mar 3, 2015 | 05:34 PM
vmystikilv's Avatar
Range Rover
bad accumulator , easy fix
Old Mar 4, 2015 | 12:17 PM
awiner's Avatar
2003 CL55 AMG
Yup. Replace at least both front and rear accumulators. One went out and the other isn't far behind.
Old Apr 5, 2015 | 10:16 PM
great thanks guys!! ill do a search on here hopefully someone has posted on how to do it
Old Apr 11, 2015 | 05:55 AM
fireman685's Avatar
2005 CL55
I've done all four. It can be a little tedious. The connections were hard to break loose. The rear one and left front are same part number and are the most likely to have ruptured. Look for any sweating hoses while you're at it. It has the potential to be a quite messy job so have plenty of rags.
