CL-Class (W215) 2000-2006: CL 500, CL 600
Replacing eis, shifter stuck in park
Old Aug 26, 2015 | 03:26 AM
Brandon Henson's Avatar
97' C280 & 00' drz-400
I'm trying to replace the e.i.s. on a 03' cl500. has anyone done this and where did you have room to remove old an install the new one. At first I pulled out the cluster but it didn't look like there was a way to bring it through there so next was the wood/center dash section & command. Which is where I ran into a problem the car is stuck in park an key won't turn in the ignition switch (reason I'm replacing the eis) so I've been unsuccessful getting the center dash/radio out with gear selector in my way tried disconnecting the inter-lock cable at the shifter to move mechanism inside still no luck kinda seems like there could be an interlock mechanism in the shifter that's broken? It is plastic... any ideas I can get pics tomorrow if needed
Old Aug 26, 2015 | 02:12 PM
tusabes's Avatar
Mercedes
If you are replacing the eis with one from another car you need to change out all the anti theft parts as a matching package from the other car - key ignition switch ecu and shifter
There are Ebay sellers who sell a matched set of these items from wrecked cars
Old Aug 27, 2015 | 03:53 AM
i actually got the shifter to move today all it took was a couple light hits from the back of my screw driver. pulled the shifter out (three 5mm allens) an opened it up on my tool box expecting to find a broken plastic interlock mechanism but couldn't see anything obvious...
oh an the eis is a new one from Mercedes an this is a customer car at the shop i work for
