CL-Class (W215) 2000-2006: CL 500, CL 600
ABC expansion hose
Old Nov 11, 2015 | 10:10 PM
Sojo40's Avatar
2006 CL600
ABC expansion hose
Can someone please let me the part number for the ABC high pressure expansion hose.
It's the hose that comes off the pump goes under the front of the engine just under the crank pulley and horseshoes back and dead ends.
I understand it is for the pressure spikes from the pump and helps take the fluid pressure by allowing the fluid to expand in to this hose.
I hope the picture I attacked shows up.
Thanks.
Old Nov 12, 2015 | 10:02 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Take the old hose to a hydraulic hose shop and have them make a new one.
Old Nov 12, 2015 | 01:12 PM
biker349's Avatar
cl600
it might be 220 320 59 72, or 220 320 53 72. not sure i believe these are vin specific, so if you contact a dealer with your vin # they should be able to tell you. i would think that both those numbers are good, but check very carefully and have the dealer check by vin#.
Old Nov 12, 2015 | 10:39 PM
Sojo40's Avatar
2006 CL600
ABC hose update
Wondering if my fellow forum members think it is a good deal for my hose replacement parts and labor, as well as, system flush (rodeo) new fluid and filters change in ABC and power steering. A star diagnostic to check everything and clear codes after repairs.
Price for everything plus tax for $853.00?
Old Nov 13, 2015 | 01:36 AM
tusabes's Avatar
Mercedes
Yes that's very fair
Just abc flush and rodeo is often $500 or more
Old Nov 21, 2015 | 08:45 PM
Sojo40's Avatar
2006 CL600
ABC hose continued
Thanks for your input I got the car done they where very professional and great tuckedat their job. Hose replaced and fluid flush with rodeo and filters changed both in ABC and power steering reservoir. Checked everything to see if any other issues, all was good.
I developed a coolant leak a day later and went back to let them know, they checked the car over from under the hood but had to put it on the car up on a lift and then found the leak steaming down from the hose end cap on the radiator they fixed it put new clamp did before and after pressure test and adjusted the coolant ph level now it is balanced and holds perfect pressure.
Also they tucked some coolant hoses that where drooping and needed to be zip locked up and and did the some for the innercooler coolant hoses.
They didn't charge me anything for locating and fixing the issue with the coolant leak and adjusting the coolant ph level and tucked low hanging hoses.
So happy right now.
