Has anybody installed the Mobridge ?
I had to order it directly from Australia, cost me around $560.
Looking for installation advice or experience
I finally installed this. Remove command, insert mobridge into most fiber optic loop. Pay attention to light direction. If you get it wrong, it will say system unavailable and command will shut down. I ran the fiber and the power into the glove box and mounted the unit there. This also allows me to have a cable aux in for guest passengers if required. The rear CD changer has to be looped out of the MOST ring. That took a few minutes in the trunk. Be careful when removing the command, the unit is heavy, the wood is old and can crack or chip.
Result is I now have full factory integration with my phone. Audio quality with my Galaxy s8 is very good. Track titles from Spotify etc are displayed on the screen. Phonebook loads correctly and syncs all my contacts.
Pretty much a perfect solution.
