Mercedes Benz » Controllers LIST
AAC Automatic Air Conditioning
AAM All Activity Module
AB Airbag
ABC Active Body Control
ABR Adaptive Brake (Chassis CAN Bus)
ABS Anti-lock Braking System
ADS Adaptive Damping System
AGW Audio Gateway
AHE Trailer Recognition
ALWR Headlamp Range Adjustment
APS Auto Pilot System
ASR Anti Slip Regulator
ASSYST Active Service System
ATA Anti-Theft Alarm
BAS Brake Assist
BNS Vehicle Power Supply Control Module
CDC CD Changer
CDI Common Rail Diesel Injection
CGW Central Gateway
CM Compass Module
COU Central Operating Unit
CTEL Cellular Telephone
DAS Drive Authorization System
DCM1 Door Control Module Front Driver Side
DCM2 Door Control Module Front Passenger Side
DCM3 Door Control Module Rear Driver Side
DCM4 Door Control Module Rear Passenger Side
DFI Electronic Distributor Injection System Diesel
DN Dynamic Navigation by Means of CTEL(K-Wire)
DS Dynamic Seat
DSP Pneumatic Pump for Dynamic Seat
DTR Distronic
EAM Extended Activity Module
EIS Electronic Ignition Switch
ESA-FL Electric Seat Adjustment Front Left
ESA-FR Electric Seat Adjustment Front Right
ETC Electronic Transmission Control
ETS Enhenced Traction System
ESM Electronic Selector Module
ESP Electronic Stability Program
EZS Electronic Ignition Switch
FSCU Fuel Pump (Drive Train CAN bus)
HFM Hot Film Engine Management
HBF Rear Control Panel
HFS Hands Free System and Microphone
HRA Headlamp Rage Adjustment
HS Seat Heater
HSW Heated Steering Wheel
ICM Instrument Cluster with Maintenance Interval Display
IFI Electronic In-Line Injection System
ISM Intelligent Servo Module
KBE-H -Rear A/C Operating Unit
KG Keyless Go
LCP Lower Control Panel
ME Motor Electronics
MSS Special Vehicle Multifunction Control Module
NSA Night Vision Assist
OCP Overhead Control Panel
OSB Multicontour Backrest
PSE Pnenumatic System Equipment
PTS Parktronic System
REDC Rear-End Door Closing Control Module
RevETR Reversible Emergency Tensinoing Retrator
RVC Rollover Bar Soft Top Control Module
SAM Signal Acquisition and Actuation Module
SBC Sensotronic Brake Control
SCM Steering Column Module
SDAR Satellite Radio
SEM Security Module
SGR Radar Sensors Control Unit(
SOUND Sound system
SPS Speed-Sensitive Power Steering
STH Stationary Heater with Remote Control
SVMCM Special Vehicle Multifunction Control Module
TAC Automatic Temperature Control
TLC Trunk Lid Control
TPC Tire Pressure Monitor
UCP Upper Control Panel
VCS Voice Control System
VBF Front Control Panel
VP Vacuum Pump Braker Booster
VR Electrohydraulic Soft Top
WSS Weight Sensing System
XALWA Xenon Headlamp
ZAN Central Display
