CL-Class (W215) 2000-2006: CL 500, CL 600
2004 cl600 a/c problem (blower motor)
Old Jul 8, 2017 | 11:18 AM
biker349's Avatar
cl600
hi, the blower on my a/c stopped working. i checked the a/c system with star. on the quick check i cleared all faults. rechecked and no faults. went into the automatic air conditioner check which runs for about 4 minutes with the a/c on and everything checked out fine. refrigerant etc. everything was well within specs. opened up fuse box in right side of engine bay. cover says air conditioning. checked all fuses and they were good. still blower motor in car is not running. the electric fan is working in the engine compartment with engine running. so do you think it's the actual blower motor? this has happened several times before and i was always able to get the blower motor running again after i cleared all faults in the quick check menu. this time it didn't work. is there anything else i can do to try and get the blower motor running again. if the actual blower motor is bad how hard is it to get to it and replace it? anyone have the part # for the blower motor?
any and all help is greatly appreciated.
thanks
Old Jul 8, 2017 | 04:41 PM
pmercury's Avatar
member
CL
thanks
Hi B
did you try with Actuations ?
that is there to test the devices one by one
Control units ect
let me know if you need help
you have developer mode ?
Old Jul 8, 2017 | 05:00 PM
biker349's Avatar
cl600
i just ordered a a/c blower regulator. when the blower was working it didn't make any unusual noises so i figure my best shot is the regulator, not the blower motor. funny, i got one new on e-bay for $28. the local parts stores want $250, oediscount wants like $150 for the regulator. for the blower motor ebay $80 new, local parts stores $450-$599, oediscount $193.50, list $258. that's quite a range of prices!!!
as i said this has been an intermittent problem for months so i feel the regulator is a good cheap guess.
i will play with star again since it will take about a week to get the regulator.
wish me luck!
Old Jul 8, 2017 | 06:28 PM
pmercury's Avatar
member
CL
good luck !
