CL-Class (W215) 2000-2006: CL 500, CL 600
ABC control Valve 0 Volts
Old Jul 19, 2017 | 09:46 PM
Andreas Grant's Avatar
2002 CL600
Hey all,
i just ran some abc tests through DAS and found that my right front and rear abc control valves have exactly zero volts when actuated. Does anybody of some easy thing I'm missing here? All other locking and control valves work fine...
Old Jul 22, 2017 | 04:41 PM
2002 CL600
Bump
Old Aug 13, 2017 | 01:57 PM
knowbenz's Avatar
Benz
Originally Posted by Andreas Grant
Hey all,
Are you checking the power at the valve or coming out of the control module? Also are you actuating the valve via SDS or pushing the button on dash?
Old Aug 13, 2017 | 02:10 PM
2002 CL600
I was checking the volts indicated on sds. I also was actuating the valves via sds.
Old Aug 13, 2017 | 02:13 PM
knowbenz's Avatar
Benz
Do the struts move when actuated?
Old Aug 15, 2017 | 12:28 AM
2002 CL600
Only the left front & rear. For the right side, only the strut blocking valves respond to actuation. The control valves do not respond and do not have any static voltage (voltage prior to actuation).
If I wanted to manually apply voltage to the valve, what would be the proper amperage? I don't want to damage it if I want to check the electrical connection.
Old Aug 15, 2017 | 08:55 PM
knowbenz's Avatar
Benz
Im not sure how many amps they pull. I have bench tested the valves hard wired to a battery and they do fine. They should have around 4-5 Ohms through them though.
