2002 W215 CL500 Dead Battery
I am unable to access my boot to jump start the car. According to the other threads, I have opened up the passenger side foot panel and I see only one point. Not sure if i should connect positive on this. Or should i dig deeper and take the rubber bit off? Also it doesn't help that i can't open passenger door as the car is parked next to a wall!.
Please help. Thanks
How far the key goes in the boot lock
Under the passenger side foot panel. Not sure if i can connect positive one the top left corner
Please help. ThanksHow far the key goes in the boot lock
under the carpet you have a rubber foam then a polyester white piece
under that you'll find the front fuse
a gray plastic piece with the big red + connected
connect the + there
