TESTED SeaFoam TT16 Automatic Transmission & Power Steering Tune Up
add a full can to the transmission
drive 100-150 miles
loosen and remove the bolt of the metalic oil pipe going to radiator (rdriver side just above the front corner of the oil pan)
empty much oil as possible by blowing air in to all the little holes you find from below
not to much pressure !
change filter, gasket, put pipe back, done
nice clean and as new
TESTED, no damage, working !
tho I wouldn't have that in my trans permanently
