CL-Class (W215) 2000-2006: CL 500, CL 600
Cl500 Strutmasters conversion not level
Old Apr 17, 2018 | 03:20 PM
Maclogos's Avatar
2001 CL500 AMG Sport
Hey All,
I recently did a strutmasters conversion on my 01 cl500 and have driven the car about 700 miles since install. I noticed springs have settled and ride height isnt crazy high anymore. Just one thing i noticed tho is the car seems to have settled lower on the drivers side than the passengers side. Its not heavily noticable on the front but the rear i notice the car is leaning lower on the drivers side. Just wondering if anyone else has had these issues or if i just need to call strutmasters for replacements components. Not hard to swap out so not the worst situation i guess. The car does seem to be more level on different streets but even then it seems to lean alot to one side if im parked on a slight slope. I will try to add a pic later today with hand measurements.
Old Apr 17, 2018 | 03:21 PM
Maclogos's Avatar
Also something else to mentoin is i noticed the wheel will rub on hard cornering on the drivers side but wont when i hard corner and weight shifts to passenger side. Thats kind of telling me something isnt right.... Should have bought yellow speed damn...
Old Apr 18, 2018 | 01:46 AM
pmercury's Avatar
member
CL
I think that you should take them of and get the pressure mesured, sounds like defective
or directly ask for replacement
or did you forgot a dead body in the trunk driver side ?
Old Apr 18, 2018 | 10:55 AM
Maclogos's Avatar
LOL! I’m already contacting them to ask for a front shock and spring assembly replacement. Just seems like defective spring is sagging compared to the others that have settled already. I do need to replace the front ball joint on the front drivers side tho. Could that affect ride height at all? I don’t think a lower ball joint affects ride height.
Old Apr 18, 2018 | 11:03 AM
pmercury's Avatar
member
CL
great, also, when you got them, make sure that ok then cut what you need to lower
go little by little, a few cm's is enought
test drive
Old Apr 18, 2018 | 11:58 AM
Maclogos's Avatar
Sadly the mechanic I go to refuses to cut springs. It’s ok tho I don’t mind the taller ride height as the streets in sf are pretty bad.
Old Apr 18, 2018 | 12:09 PM
Maclogos's Avatar
Here is a pic from the rear. You can see the car is leaning to the drivers side more. I can get a front pic later which shows it even more.
Old Apr 18, 2018 | 12:17 PM
Maclogos's Avatar
Even the back is showing uneven balance but i think its because the front is lower and causing the drivers side to dip.
Old Apr 18, 2018 | 01:01 PM
pmercury's Avatar
member
CL
maybe your chassis bend.. sometimes that happens with some jump accidents
ABC would balance that I as invisible I guess
you know how many owners had this car and who ?
Old Apr 18, 2018 | 01:29 PM
Maclogos's Avatar
car only had 2 previous owners and both took care of the car except maintaining the abc fluid and filters. Pretty common I guess. I did hit a pothole on the front drivers side that was pretty bad but didn’t notice any bent arms or bad bushings. Car still drives ok but needs alignment and a ball joint. Maybe alignment and ball joint might help?
Old Apr 18, 2018 | 01:41 PM
pmercury's Avatar
member
CL
yea then probably not the frame
but the rear is very complicated, if you look in one of my posts, I swappet everything with rubber on the rear axe
https://mbworld.org/forums/cl-class-...n-bars-dy.html
Old Apr 18, 2018 | 02:05 PM
Maclogos's Avatar
i will be sure to check that out. Yeah frame damage would be pretty apparent and when I check shock towers and the area around them there is no indication of frame or body damage. I’m gonna see if strutmasters will send me a replacement front assembly and then go from there. It’s just weird. Last time I was at the Mercedes dealer picking up a part I checked the clearance at each wheel and it was even. Then when I got home I checked again and the front left was much lower. About a fingers difference from left to right.
Old Apr 18, 2018 | 08:38 PM
tusabes's Avatar
Mercedes
Get a yard stick or tape measure , and while on perfectly level ground , measure the distance from the ground to center of fender lip at all 4 corners
the fronts should be close to equal , as should the rear two
also are all four of your tires a matched set ? Mismatched tires are common when someone in replaces just one flat
Old Apr 18, 2018 | 09:21 PM
Maclogos's Avatar
Im actually getting ready to measure the difference now. Front tires are same brand and size. Rear tires are same brand and size. On factory 18’s amg rims staggered.
Old May 10, 2018 | 03:19 AM
Zaid Alobaidi's Avatar
cl500,c300,c240,e320
Strutmaster garbige turn my car to bike rolling on highway car ride make me feel tired and wanna go home
Old May 10, 2018 | 09:30 AM
Maclogos's Avatar
Well to update people turns out my car was not as good as I thought. Found out at some point the odometer was rolled back and coded to look legit. Not sure how it was done but it was. So I got rid of the car and got a e55. Best decision ever.
Old May 11, 2018 | 04:55 PM
pmercury's Avatar
member
CL
rolling odometer back is easy with a blocker
these folks solder a module to the EIS (ignition key block)
once that is in place they hook up a odometer with desired mileage
the odometer tries to read from EIS and Trans selector but info is blocked by the blocker module
so odometer stays on what they set it to
other method is replacing all 3 devices from low mileage donor car
only VIN needs to be corrected then
Old May 11, 2018 | 05:04 PM
pmercury's Avatar
member
CL
right name is CAN Blocker or Can filter
https://www.google.fr/search?q=W220+...=1823&bih=1143
Old May 11, 2018 | 05:11 PM
Maclogos's Avatar
Well now I know... either way the car started showing signs of multiple failures so it was just time to move on. Short lived but glad I got the e55 now. It’s just a overall better family cruiser. The CL still a great car tho. Just didn’t meet the requirements I needed.
